Blank iFrame content (click events not working)
Description of the issue
On Safari and Chrome, site is displaying properly. After update to Version 0.66.99 Chromium: 75.0.3770.100 (Official Build) (64-bit) on Macbook Pro (Mohave 10.14.5), part of the page (main section) is blank.
I did find that a script block is missing from the page which sets up the link to populate the iFrame src.
Here is a snippet of what it should look like; however, the script block is missing from Brave.
  <div id="panelL_menuPanel_sp2_tree2_node_0_1" class="tnDiv tnMid" data-url=
  "/StagingAcma/pages/so/so301000.aspx?HideScript=On" data-value=
  "047e4dca-ffbb-4eeb-8e4a-681be8dcc7ba" data-path="047e4dca-ffbb-4eeb-8e4a-681be8dcc7ba">
    <span class="treeNode treeSelected">Sales Orders</span>
  </div>
  <script defer="defer" type="text/javascript">
    var panelL_menuPanel_sp2_controls =  new Array("panelL_menuPanel_sp2_tree2:PXTreeView");
  </script>
  __px_cm(window).registerControls(panelL_menuPanel_sp2_controls);
  </script>
Exact URL of the website in question
This is an Acumatica ERP page which is internal to our network.
This is also a problem with other developers using the updated Brave version.
I reverted back to the past version and it works correctly.
I have NOT scoured the web to find other sites with this problem.
Did the issue present with default Shields settings? [Default states are: Block: Ads/Trackers, 3rd Party Cookies, 3rd Party Fingerprinting Allow: Encrypt Connections enabled (HTTPS), Scripts] (yes/no)
I turned off shields. I also attemped flipping switches to many of different global settings.
Does the site function as expected when Shields are turned off? (yes/no)
no
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no)
no - no matter the settings site still breaks (missing script block from content - see above)
Does the site function as expected when using Chrome? (yes/no)
yes
What Operating System and Brave version/Build are you using when you encounter the issue?(See the About Brave page in the main menu)
Brave Software Inc
Copyright 2019 Brave Software Inc. All rights reserved.
Brave 0.66.99 Chromium: 75.0.3770.100 (Official Build) (64-bit)
Revision cd0b15c8b6a4e70c44e27f35c37a4029bad3e3b0-refs/branch-heads/3770@{#1033}
OS Mac OS X
JavaScript V8 7.5.288.23
Flash (Disabled)
User Agent Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/75.0.3770.100 Safari/537.36
Command Line /Applications/Brave Browser.app/Contents/MacOS/Brave Browser --disable-chrome-google-url-tracking-client --disable-domain-reliability --disable-features=AutofillSaveCardSignInAfterLocalSave,NetworkService,LookalikeUrlNavigationSuggestionsUI,AutofillServerCommunication,AudioServiceOutOfProcess,DefaultEnableOopRasterization,TranslateUI,UnifiedConsent --enable-dom-distiller --enable-features=NewExtensionUpdaterService,DesktopPWAWindowing --no-pings --enable-features=DesktopPWAWindowing,NewExtensionUpdaterService --disable-features=UnifiedConsent,TranslateUI,DefaultEnableOopRasterization,AutofillServerCommunication,LookalikeUrlNavigationSuggestionsUI,AutofillSaveCardSignInAfterLocalSave,NetworkService,AudioServiceOutOfProcess --flag-switches-begin --flag-switches-end
Executable Path /Applications/Brave Browser.app/Contents/MacOS/Brave Browser
Profile Path /Users/[name removed]/Library/Application Support/BraveSoftware/Brave-Browser/Default
Variations 5040e8a-5040e8a
c134752e-f685ead3
2c707b42-dcf7018a
411b6d4e-3f4a17df
d01ab0d3-60c33fc0
8927cedd-3f4a17df
16e0dd70-3f4a17df
414bf2d2-3f4a17df
ba11b117-5b05287a
4ca682fe-3f4a17df
551157b-3f4a17df
f88a4127-2874767e
4b8c3f4-3f4a17df
b7e2524c-c92d551c
411c711e-3f4a17df
1800d8bb-3f4a17df
8f029c91-3f4a17df
61832c80-3f4a17df
cc20827f-77c422c
9853922b-3f4a17df
776de70c-e0278d3d
ed9149a9-3f4a17df
34d450b1-3f4a17df
c70841c8-a2567007
14bdbe54-e8c7a65b
d8343fa3-3f4a17df
b517d646-3f4a17df
8ee5ed19-c3125ea2
74658432-fa79b94c
4f9b5d89-3f4a17df
aacdc39d-80f9a33e
c36cdb78-3f4a17df
5274eb09-3f4a17df
d6d4ee9a-3f4a17df
2729b628-3f4a17df
44827ee5-3f4a17df
332a4d9b-8e8e4a2b
6a116980-3f4a17df
3f79ac13-3d47f4f4
8f1e27f-3f4a17df
6cb3969e-3f4a17df
40de7b13-1aa41b58
9b4c4257-3f4a17df
43f62d3b-3f4a17df
9e5c75f1-30e1b12b
2594bdf4-3f4a17df
6fa07eb4-7282ca76
2981bcb4-3f4a17df
5139837c-3f4a17df
4934552d-3f4a17df
7f8176d9-3f4a17df
9504402-d0e5ea2a
6c66bd8d-b2047178
23a898eb-fc93cf74
7a5ba892-3f4a17df
d1cd70a5-3f4a17df
4ea303a6-3f4a17df
ac8d4708-5460eccb
b19465ab-b19465ab
6e6e0c7e-3f17a7d8
95876445-2b71ffe4
2b33233e-881ca6c9
4da5ae82-3f4a17df
56302f8c-2f882e70
b2612322-8a9180b2
3dba712-a2d707c6
ad6d27cc-85d38e8d
cec9a952-9a6c5085
f56e0452-3f4a17df
8576baf1-3f4a17df
2e7f6029-88947c67
d00fcbde-3f4a17df
d840bbac-3f4a17df
930e30f5-3f4a17df
732f0134-3f4a17df
9a2f4e5b-9ded16b9
1354da85-522c33b8
494d8760-3f4a17df
f9e5da91-508355f5
b1ceb06f-6b7b34d
b0ea13bc-3f4a17df
47a2af3f-3f4a17df
94e68624-803f8fc4
cc73f8a1-3f4a17df
b4e8892d-a2d707c6
7e91b7bd-c6da37cb
6204e469-3f4a17df
41ddf744-c78ce173
Welcome to community @meritex!
Hi @fanboynz, would you mind taking a look at this when you have a moment?
It’s a bit hard to troubleshoot give its internal use, is there way to replicate for me from the outside?
Does it work it private mode? (with/without sheilds enabled?)
We changed a few things in the blocking for Brave Nightly, could you test that also?
I’ll take a look at the Nightly build and report back. Sorry for the delay - I was on vacation.
Thanks for taking a look at this BTW.
@fanboynz Looks like the Night Build from today fixed the issue.
Thanks.
Great to hear! Thanks for the report, I guess we’ll just wait on changes from Nightly to filter down to brave Release.
@fanboynz FYI - Yesterday we had a few reports that the newest version of Chrome that is out now have the same issue - funny. I’m sending those employees to Brave when it’s fixed :slight_smile:
@fanboynz
Acumatica release a workaround on Chrome and a release for their app as well. This works in Brave
  • just replacing “chrome” with “brave” below.
  1. Type chrome://flags/ in the browser address bar and press Enter.
  2. Find Enable lazy frame loading section.
  3. Select Disabled .
  4. Restart the browser.
