Why Brave is ignoring what users asking prominently? Same issues since start!
Issue - After OS reinstallation or Reinstalling Brave after flushing!
*Losing BAT
*Losing Bookmarks
One Simple Solution
*Browser Login option - Sync all data under one account regardless of devices or reinstallation.
I
don’t think Cloud Storage is an issue for Brave!!
They’re working on being able to store rewards on the Brave Wallet which is cloud based. But note, you still will have to connect to Uphold/Gemini to be able to withdraw BAT out of Brave
You can get more information into this here →
You are not getting the point! As you said in order to withdraw connect Brave wallet to another wallet Or lose all your earnings, right? Why there is a need for two wallets and if it is then why does one have to suffer? Also, how to get back all the Bkmrks and login credentials that we stored trusting Brave?
If you had a sync chain you can add this device back to retrieve them.
Because Brave as of now Brave doesn’t have a money transmitter license which is required for giving out BAT. Also a lot of regulations from governments which will make it too complex got Brave. Also Brave will need to do KYC.
