When going to brave://extensions/ in Light mode, the sliders are not visible
When using Light Mode in brave and then going to brave://extensions/, the sliders that should be visible are not visible in light mode. When switching to dark mode, the sliders to enable or disable extensions is visible, however in dark mode, the switch is a white box.
