Website does not work, HELP
Hello,
I took off the acceleration and also I took off smooth scrolling but many sites do not work still.
For example this site:
https://www.mining-dutch.nl/pools/account.php?page=login
I am trying to log in but the CAPTION checkbox cannot be checked.
Can anyone try and check it? It does not register, so now, I cannot even log into the website at all.
Can you tell me how I can fix this?
Thanks
Hi @fynxgloire,
Did you mean Captcha? Did you have site isolation enabled under Preferences > Security? This setting may causing an issue with Captcha.
:slightly_smiling_face:
Ah yes thanks, it worked.
What is this setting for and why doesn;t it work?
Hi @fynxgloire,
You can read more about SSI here
It’s an experimental feature. It’s a known issue where enabling this setting may causing an issue with some sites/extensions.
:slight_smile:
