All sorts of problems using the Vanguard.com website when logging on to my account.
This has gone on for months now.
After entering logon, almost always get 'The site can’t be reached, connection was reset ’ message.
Then I have to hit reload several times, then maybe in a few seconds, something will load regarding the overview of my personal account. But it will be missing portions of what should be displayed. Problems like this persist (‘site can’t be reached’, partial data display’) Have to reload multiple times, and even then some screen info won’t show up
I turned off Brave shields, and also turned off ublock, but problems persist.
I have absolutely no problems when using Firefox to access my account.
In order to recreate the problem, you’d need an account at Vanguard.
Below is the frequent response to logging in, or switching to another screen within my account.
In order to demonstrate the missing sections of data within my account display, I’d have to screenshot my personal financial data. Hopefully someone in support has an account.
Windows 11, Dell desktop
Version 1.63.165 Chromium: 122.0.6261.94 (Official Build) (64-bit)
So then I clicked on the blue ‘reload’ half a dozen times, each time getting the same screen again, then finally, I got this error screen which I have never seen before:
I tried reloading multiple times, no effect. I turned off brave tracker blocking, and also ublock origin, reloaded the page, and that had no effect.
Next, I went to Firefox, followed the same path I just described. No messge about ‘reset’ , no message about ‘problem on our end’. Instead, I got the correct result - see below.
Failures described above occur in chrome as well, but not to the same degree. I get a timeout message, then the correct screen shows up a second or two later. I don’t get any ‘error on our end’ from vanguard.
So vanguard is broken in chrome, but brave has made it worse, somehow.
Did you you try the steps I outlined in the prior message? And if so, what was the result?
