Using Bing as the default search engine sometimes causes a white screen
When using Bing as the default search, and then typing directly into the address bar, it just loads a white page. The frequency I’d say is every few weeks or so. But I’ve had this happen for a year more or less. It’s currently happening to me, so Bing through the address bar search is unusable.
Using private window doesn’t fix the issue. Nor does reloading using ctrl+F5, nor does clearing the site’s cookies and data from the search bar.
https://www.bing.com/search?q=%s
This is the format used by Brave by default to substitute a search term when Bing is the default.
Yes
No
No
Not installing it, but I do have Chrome Portable, from PortableApps.
Site works? Yes and no.
There’s a difference. Chrome allows for changing the default to Bing as well, and it even shows when you check it in settings:
BUT when actually searching through the address bar, the URL that it goes to is the following:
https://www.bing.com/search?q=test&PC=U316&FORM=CHROMN
‘test’ is the search term I used, but notice the &PC=U316&FORM=CHROMN
Brave does not have this. Brave does as instructed, and purely goes to, and blanks on:
Weirdly, what I find by setting up a manual search engine using /bi since the default /b URL cannot be edited, if I do something like this:
https://www.bing.com/search?q=%s&qs=n
Then using /bi, which should function just like /b (the default), will always work without fail.
From what I can determine, it seems that using the raw…:
…Like Brave does, has some issue with either the browser itself, or with Bing not liking it.
When I set up a manual /bi search engine in Chrome like in Brave, Bing refuses to load as well in Chrome just like in Brave.
Version 1.78.97 Chromium: 136.0.7103.93 (Official Build) (64-bit)
Having the same issue and it doesn’t appear to just be Bing however, I attempted Google as the browser just because it’s the “widely used” choice by folks and I’m still getting that blank white screen.
