Oh and I did the advanced option for blowing out history, cookies, sessions, etc. reset the computer. resetting Brave Wallet does not appear to work. I checked the brave://components page yesterday and today and there are components that were not updating on their own (I tried and restarted the browser, but no change in behavior). many of the NFTs are now showing as watch-only (Webacy, UD nfts).
Ethermail - Metamask/Phantom pop up immediately. No options on the page now for Brave at all, I’m not even getting to the Thor Protocol stage. the wallet says I’m connected but nothing happens.
Dappradar - Metamask/Phantom pop up immediately. but I can log into the dapp with Brave Wallet.
Wirexpay - connects to Brave wallet easily. no popups from metamask/phantom.
I asked Ethermail that yesterday, here’s what they said:
Thank you for reaching out.
It sounds like you’re facing a wallet detection issue at the Thor Protocol authentication stage. Unfortunately, the Brave Wallet sometimes isn’t recognized correctly if other wallet extensions like MetaMask or Phantom were previously installed, even if they’re now disabled.
Here are a few suggestions to help:
Fully remove MetaMask and Phantom extensions – Not just disable them, but uninstall them completely and restart your browser.
Clear browser cache – This helps ensure stale wallet session data doesn’t interfere with authentication.
Update Brave – Ensure you’re on the latest version of the Brave browser.
Try Incognito Mode with only Brave Wallet enabled – This can help isolate the Brave Wallet for proper detection.
If the issue still persists after this, we recommend trying to access your account from another browser temporarily (such as Chrome with only Brave Wallet installed), or wait for upcoming support updates that improve multi-wallet handling.
We know this can be frustrating and truly appreciate your patience. Please let us know if the problem continues — we’re here to help.
Thank you for your continued support and for being a valued member of our community
EtherMail Customer Support
