About a week ago, I updated both my macOS (Monterey 12.4) and my Brave to 1.39.120.
Since then, when I’m watching a stream on twitch, I have to be focused on the tab of the stream in order to have the sound of it. Each tab I switch tab or desktop, the stream keeps running but without the sound. It looks like Brave is cutting sound from twitch tabs when unfocused.
I was thinking about a a new feature from macOS but when I use Safari or Chrome instead, it works perfectly.
For now the only solution I found is to run the stream I want to watch and listen in a separated window but it only works for 1 desktop.
Do you guys have any solution I could try to fix it?
