Briefly describe your issue:
After reinstalling Windows, I’ve copied userdata from the old to the new one. Everything worked perfectly until I noticed I’m not getting any rewards for the new tab ads, also not receiving any notification ads in the last month. I’ve tried to restart ads but now after turning it off I can’t turn it back on.
Windows 10, Brave 1.30.89
No
Yes
Are you using a VPN? (yes/no)
Sometimes
Yes
