When using the Translate to English option it rarely works:
there is a very small % chance for it to work 1st go
most of the time if it works it works for anything from a few seconds to a few minutes, max,
usually you have to repeatedly click on the reload translation option in Brave if it doesn’t work and then sometimes this makes it work
when trying to use Google translate, because Brave won’t do it, I do not get the ‘paste’ option in the translation box. to get the paste option, in the right click box, you must right click 30-40 times in the box. If it appears sooner then you are lucky
MS Office was also laggy when trying to paste stuff in it, but I did have a few tabs open (32GB RAM) I tested it when Onion was open and there was no lag
It is not doing it now but I only have 2 tabs open.
The website which I was using was Allegro pl + others, but it happens on most sites, but some are, slightly, better than others.
I MUST be able to translate and Brave seems to be worse now than before
Version 1.56.20 chromium 115.0.5790.171 official build 64-bit
W10 pro V 22H2 OS build 19045.3324
My Android version now has problems after the update too, so I have to post about it there. :-/
your posting and editing system f éd up, you can sort it as I have wasted enough of my time with this browser!
