Torrent Help , help me c3po
Is there anyway to set it so brave does not use the built in torrent downloader I would like to download the magnet link myself and run through my own…
thank you friends! (((::
Hi @Zmur,
You should be able to disable the Torrent Viewer via Preferences > Extensions. :slight_smile:
Hope that can help,
:slight_smile:
#3
Yes, it is as @eljuno has stated.
I am including an annotated screenshot for you.
closed #4
