Do I have to click the Ad Banner in order to get credit for the ad, or can I just let it slowly fade out and still have it count?
I don’t have any that say dismissed. I only ask because after seeing the same one for the 50th time, I get tired of clicking on it. I thought in order to receive credit for it, I must click on it, go to the site, and then look at it for a couple seconds.
According to what you just wrote I suppose I can just ignore the banner that pops up and keep working then correct?
I provided a reference, that seems to apply to your questions.
If you read the reference material, it will answer your question - specifically, you get credit for what you Viewed according to the table that you see in that reference.
Sorry I didn’t even notice the link. Merci
