Tip: workaround to Brave crashing when Importing from Edge
Hi All,
Brave 1.74.51
Whenever I try to import Edge’s setting into Brave, Brave crashes.
Workaround: install Firefox. Import Edge into Firefox. Then import Firefox into Brave.
HTH someone else,
-T
It seems like there’s a bug with importing Edge’s settings directly into Brave in version 1.74.51. Using Firefox as an intermediary to import Edge settings into Brave is a clever solution.
