Theme does not reset
Would you be willing to delete all your extensions?
Yeah I can set them back up again afterwards so no problem
@Frazic
Can you try quitting all running instances of Brave.
Removing all extensions via that extensions folder:
C:\Users\YOURNAME\AppData\Local\BraveSoftware\Brave-Browser\User Data\Default\Extensions
And then reopening Brave.
Hey Aa-ron,
I closed Brave, deleted the Extensions folder and reopened Brave. Nothing has changed on my end, although my Extensions folder just popped back with all the extensions in it as before.
Sounds like the extension weren’t removed if they’re still in the folder.
When removing the extensions can you walk me through your steps?
Sure!
  1. Quit all Brave instances
  2. Go to folder at C:\Users\YOURNAME\AppData\Local\BraveSoftware\Brave-Browser\User Data\Default\Extensions
  3. Delete said folder
  4. Open Brave again
  5. Observe that the Extensions folder created itself again and all extensions are back in Brave, although they do say “broken” and need repairing
Would you be willing to uninstall and reinstall Brave?
