Attempt to switch to a tab that was already open
Tab has no content displayed, just a blank white color
Reload the tab
The blank white turns into gray instead (I have dark mode on) with clickable links
The webpage should display content normally and everything on it should be visible Brave Version( check About Brave):
Brave is up to date
In the blank gray space, links can be moused over (cursor changes to a hand/finger, indicating there’s a link that can be clicked on) but clicking on the link loads that link’s page with the same result (another blank gray color with clickable links).
Reloading does not help, but visiting another webpage, letting it load completely, then returning to the previous webpage causes the page to load correctly.
Same problem here. I’ll have an open tab, go to another one, come back to the first one… and it’s blank. Can take as long as 10-15 seconds for the content to reappear. What’s with that???
