impossible to enter a new synchronisation code: I do not have the button “I have a synchronisation code”. So how to proceed ?
Thanks a lot
eljuno
April 8, 2021, 12:22pm
What did you see on your end? Most likely that device is already on a sync chain as that button only available on setup page.
Thank you: indeed, it’s already synchronized with an other device. But I have the possibility to add a new device: I have a code to enter in the other device, but impossible to enter this code.
I find that the process of synchronization is not clear at all.
eljuno
April 8, 2021, 12:55pm
#4
Hm, this one @GRG6060 .
You’ll need to reset sync on your other devices in order to see the button. On the sync page, you should see “Leavy sync chain” button.
The expected flow:
you set up one device (1st device) as the “chain creator”, so you get a sync code
and on your 2nd, 3rd, n devices, you just need to enter/scan code from the first device.
Again, as “I have sync code” button only available on setup page.
system
closed
May 8, 2021, 12:55pm
#5
