Stopping notifications in upper right corner of screen
I cannot stop the notifications that appear in the upper right hand corner of the screen.
I check the notifications section and the only thing I have approved is email notifications but I get so many other ones. 2012 IMAC.
@wtsheff you may have Brave Ads enabled under brave://rewards. If you have this option enabled, Brave will show you an ads as a system notification.
Blog post about Brave Ads https://brave.com/brave-ads-launch/
Yes, I think that was it.
Thanks.
