STATUS_BREAKPOINT Brave pages dead: Downloads, settings, Help, bookmarks management
Brave (internal local) pages:
Downloads,
Settings,
Help,
(all are dead pages now on Brave),
Just get
“Aw, Snap!” “something went wrong while displaying this webpage”
“error code STATUS_BREAKPOINT”
cant quote you the version, as even “help” page is crash, but I just downloaded the latest version from Brave.com community (June 11, 2021). Same problem as the version I had installed.
Brave had been working OK for more than a year on my Win7 system.
Brave "Ad Block " page still opens… NO Boxes are checked.
I also run programs/applications for several years (with no issues)
These security programs:
Eset AntiVirus
Eastek Eraser
CCLeaner
and these internet/network programs:
ChromeBrowser (no issues)
CCleaner Browser (no issues
TORBrowser (no issues)
Viber (no issues)
Surfshark VPN (no issues)
Hey community… I found this info on the community… and the JAVA setting fix worked !. I did not do the beta-version install this other brave-browser user tried. Just the Brave://flags (then change java setting to “ON”)
between the “…”
Same bug here.
I renamed the default profile in order to create a new one at the start up and nothing has changed.
So i decided to install the beta and this one works now. And i moved the old profile to the beta, it still works.
After some research, i found the option blocking the setting webpage:
You can still use the brave://flags/
if you disabled the option : Latest stable JavaScript features
Turn it on
