I’m stuck in loop. I’m not able to claim rewords. As I click on claim I get error.
Please help
I’ve been facing the same issue. Stuck in the loop. Clicking on the claim button returns “Oops something is wrong Please try again” This has been such since 10 or 11th.
I tried to look for related posts but seems there aren’t much and support team hasn’t come across it yet because there has been no response from the support team in any of the posts related to this issue.
Does your device pass Safetynet? You can test here: https://play.google.com/store/apps/details?id=org.freeandroidtools.safetynettest&hl=en_US&gl=US.
Yes it does pass the test. Here is a screenshot provided of the test. The blurred part is just an ad and nothing related to the test.
Thanks I tried this way and it helped.
Is it something new? I’ve never known that rewards could be claimed this way.
It’s been there for quite some time as an alternative way. It may not work all the time but generally works if claim has been failing for some time.
Is it available just for Android or present in desktop as well?
Your comment lit up a bulb in my brain.
I’m a root user and I’m in AOSP development. which clauses me to change roms frequently. Some roms don’t pass and even though some may pass they for sure will have this issue.
Solution for people like me:
If your company policy allows you can suggest this fix to other users also.
Thanks Steeven
My issue is solved.
Cheers!!!
I did tried that but sadly didn’t work for me.
