[Solved] Max number of tabs per set - first window vanishes
solved
When I exceed my max number of tabs per set and Brave opens a new window, the first window does not remain open. The first window vanishes and I’m unable to find it or reopen it by “Reopen Last Closed Window” in History.
I have to search back through my history to try to restore it tab by tab. Not sure if I’m doing something wrong, but it would be really nice if the first window could remain open when Brave opens the second window.
I’m using Mac OS 10.12.2. Thanks!
Perhaps you’re not noticing the tab pane manager? It is how we manage sets of tabs.
#3
You’re right, I didn’t see that! Thank you so much :slight_smile: I should have also said that otherwise I’m liking Brave very much. I was using Safari and liked it, but I’ve been recommending Brave to everyone I know!
closed #4
