(Solved) HELP NEEDED: Red and Gray Toggle Buttons
Does RED toggle mean the feature is on or off?
Thanks
In the Preferences? Red means it’s on, grey means it’s not.
#3
@iterating, yep. Like @Azure said (thanks azure! :slight_smile: ). Red/Orange mean the toggle is on/active/enabled.
Will closing this thread since the question is answered. :slight_smile:
If you have another question or request or face some bugs, please open a new thread for each.
Thank you,
:slight_smile:
#4
Thanks and sorry so dumb!
closed #5
