The fonts (names) on all tabs opened and on webpages look soft and blurry in Brave.
I have found a remedy for this - turning off ‘Use hardware acceleration when available’. Once this is done that fonts on tabs and everywhere else look sharp.
However, I am a photographer and once I turn off ‘Use hardware acceleration’, then this seems to disable Color Profile settings, so that my images on my website look over-saturated. I have changed the settings in ‘flags’, but colour management only seems to work when hardware acceleration is on. Display D3 P65, gives me accurate colours, but only with hardware acceleration turned on.
Steps to Reproduce
This is a constant issue. I have even uninstalled and downloaded Brave numerous times.
The second image is with Hardware Acceleration turned on, with the soft and blurry text.
Every time I use Brave
**Operating System and Brave Version
Windows 10 / Version 1.10.97 Chromium: 83.0.4103.116 (Official Build) (64-bit)
