Slow start-up (25s) after initial installation[solved]
  1. system : arch linux kernel 6.5.7-zen2-1-zen
  2. env : DWM
  3. first-time installation but very slow start-ups (over 20s)
normal startup time
Version 1.59.117 Chromium: 118.0.5993.70 (Official Build) (64-bit)
no change of settings or extension except deactivation of material acceleration
can the browser be started from the command line with debug or log flags?
chromium starts up normally
Hello @apojul
you can use this flag when starting brave from the terminal --enable-logging=stderr
and this a list of flags that you can use with brave https://support.brave.com/hc/en-us/articles/360044860011-How-Do-I-Use-Command-Line-Flags-in-Brave-
in short words when you need to look for some flags in brave look for it in chrome (unless it custom option added by brave) and most of the time same will apply
hope that help and have a nice day :slight_smile:
thx @justsomeone1,
I’ve tested it and it takes a while to start up on the following lines
[196169:196169:1017/142253.465010:WARNING:sandbox_linux.cc(393)] InitializeSandbox() called with multiple threads in process gpu-process
[196170:196170:1017/142308.437265:INFO:child_thread_impl.cc(926)] ChildThreadImpl::EnsureConnected()
apojul
you welcome @apojul
could you add this flag after the previous one --disable-gpu this will disable hardware acceleration
maybe it gpu driver issue
do you have dual gpu card ? if yes could you start brave with each one and see if the issue related to one of them (of course without using the disbale gpu flag)
I’ve tried but the result is the same:
my graphics card is a gt710 and
I’ve installed the aur nvidia-470xx-dkms package,
my motherboard is an MSI MPG B550 Gaming Plus and
my processor is an AMD Ryzen 5 5600.
could you change the desktop environment and see if it work or not ?
no desktop environment just the window manager DWM
could you try to use different one?
I’m going to try another window manager
issue is the same
issue is with kwallet
[225487:225487:1019/164659.807443:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.isEnabled: object_path= /modules/kwalletd6: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd6 was not provided by any .service files
[225487:225487:1019/164659.807467:ERROR:kwallet_dbus.cc(112)] Error contacting kwalletd6 (isEnabled)
[225487:225487:1019/164659.807601:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KLauncher.start_service_by_desktop_name: object_path= /KLauncher: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.klauncher was not provided by any .service files
[225487:225487:1019/164659.807612:ERROR:kwallet_dbus.cc(81)] Error contacting klauncher to start kwalletd6
[225487:225487:1019/164659.807731:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.close: object_path= /modules/kwalletd6: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd6 was not provided by any .service files
[225487:225487:1019/164659.807741:ERROR:kwallet_dbus.cc(503)] Error contacting kwalletd6 (close)
[225487:225487:1019/164659.808185:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.isEnabled: object_path= /modules/kwalletd5: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd5 was not provided by any .service files
[225487:225487:1019/164659.808195:ERROR:kwallet_dbus.cc(112)] Error contacting kwalletd5 (isEnabled)
[225487:225487:1019/164659.808307:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KLauncher.start_service_by_desktop_name: object_path= /KLauncher: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.klauncher was not provided by any .service files
[225487:225487:1019/164659.808315:ERROR:kwallet_dbus.cc(81)] Error contacting klauncher to start kwalletd5
[225487:225487:1019/164659.808428:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.close: object_path= /modules/kwalletd5: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd5 was not provided by any .service files
[225487:225487:1019/164659.808438:ERROR:kwallet_dbus.cc(503)] Error contacting kwalletd5 (close)
[225487:225487:1019/164659.808784:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.isEnabled: object_path= /modules/kwalletd: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd was not provided by any .service files
[225487:225487:1019/164659.808794:ERROR:kwallet_dbus.cc(112)] Error contacting kwalletd (isEnabled)
[225487:225487:1019/164659.808900:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KLauncher.start_service_by_desktop_name: object_path= /KLauncher: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.klauncher was not provided by any .service files
[225487:225487:1019/164659.808909:ERROR:kwallet_dbus.cc(81)] Error contacting klauncher to start kwalletd
[225487:225487:1019/164659.809012:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.close: object_path= /modules/kwalletd: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd was not provided by any .service files
[225487:225487:1019/164659.809028:ERROR:kwallet_dbus.cc(503)] Error contacting kwalletd (close)
[225487:225487:1019/164659.809374:ERROR:policy_logger.cc(154)] :components/enterprise/browser/controller/chrome_browser_cloud_management_controller.cc(163) Cloud management
controller initialization aborted as CBCM is not enabled.
[225487:225801:1019/164659.867810:ERROR:object_proxy.cc(577)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[225487:225801:1019/164659.867923:ERROR:object_proxy.cc(577)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[225487:225801:1019/164659.868013:ERROR:object_proxy.cc(577)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[225487:225487:1019/164659.884793:ERROR:network_service_instance_impl.cc(663)] Network service crashed, restarting service.
startup is fine when I use the “password-store=basic” flag
how to set the default password-store in basic
solution : Password-store is wrong [solved] - #2 by apojul
glad to know that you figured it out well done
thank you for the help.
you welcome @apojul :slight_smile:
better solution
