Shift or Ctrl + Click does not allow selecting multiple tabs
- Use GTK Theme
- Hold SHIFT to select range or CTRL to select individually + Left Click on Tabs
- Jumps to the other tab you are trying to select in range or individually. Will not select more than one tab.
Tabs will group select so that you may close them together or bookmark them together, etc.
v1.61.69
Linux only. Works on Windows.
