Shakes & Fidget does not load on Brave
It might seem funny, but I have had a problem with the site https://sfgame.net/ for a few months. I can not properly load into the game. Is the problem on my side or Brave has a problem with it ?
@TomFecko,
Not just you — looks like it loads about half way then freezes for me as well. Disabling Shields resolves the issue — looks like it’s blocking the ads/trackers specifically causing the issue.
cc @fanboynz to take a look here.
In the meantime if you want to play the game in Brave you’ll have to do so with Shields down.
