foren
December 29, 2018, 11:30pm
1
i set in my privacy settings block all cookies and block all fingerprints. So when ever i delete my browser cache and restart brave the settings are gone. And its back to standard. This happens even with a profile.
Also iam not able to get 1password addon working.
Version 0.58.18 Chromium: 71.0.3578.98
eljuno
December 30, 2018, 1:15am
2
Thanks for reporting @foren ,
We’ve an issue logged for shields settings here https://github.com/brave/brave-browser/issues/2400
For 1password, what kind of “not working”?
Thanks
foren
December 30, 2018, 9:15am
3
it simply wont work. I installed the addon several times with no success. It says app needed. i have the full version 6xx.
eljuno
December 30, 2018, 1:22pm
4
Ah, I see. Thanks for the info @foren .
IIRC, you need 1password version 7 to make it compatible with extension that you installed on your Brave.
cc @Mattches for confirmation or maybe workaround for this.
@foren ,
Are you saying 1p7 won’t work either? If so, what happens when you try? What operating system are you using?
system
Closed
January 28, 2019, 11:30pm
7
