Hi,
I can’t change the default search engine with Lilo.
It appears in the Preferences but is never shown in the address bar.
Thanks for your help.
Best regards.
Ted
Hi,
Best regards.
Ted
Hi @Ted,
Welcome to community! What OS and Brave version are you using? I can help to troubleshoot.
Thanks!
Steven
Hi Steven,
/What OS and Brave version are you using?/
Mac OS Sierra 10.12.6 (16G1918)
Version 0.62.50 Chromium: 73.0.3683.86 (Build officiel) (64 bits)
Thanks a lot if you can help.
Ted
@Ted19 Thank you for bringing this search engine to my attention.
Lilo, StartPage, DuckDuckGo and Qwant should really be the only search engines’ Brave supports.
Hi @Ted19 ,
I was able to add Lilo as my default following these steps:
First I performed a search using Lilo. Then I took that URL and replaced the search word at the end with %1.
The next step was to paste this URL into the 'URL with %s in place of query field."
Hit save, and then set as your default by clicking the 3 dot menu on the far right:
That should do it! Please let me know if your issue persists.
You have the wrong Ted, sorry.
Hi Steeven,
Thanks for trying.
What do you mean by “The wrong” ?
Version ???
TEd
after deleted the history of your browser go to setting then click on privacy then click to choose this for default browser. (jingo holidays)
Hi Jingo Holidays,
Choosing Brave as the default browser didn’t solve the problem of Lilo set as a default browser
Thanks for trying
Ted
Thanks for that feed back
Ted
