hello @tantan, thank you for reaching us out. Are you using extensions? If so, please try removing all of them or one by one to see which one might be causing the issue.
If it does not work, can you try disabling Hardware Acceleration
Also, going to brave://flags > Search 'Vulkan' > Disable Vulkan > Retest
Let us know if that resolves the issue. Regards.
