i get following errors/warnings when following the ubuntu script (v16+) on brave’s site:
The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY A8580BDC82D3DC6C
: GPG error: https://brave-browser-apt-release.s3.brave.com stable InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY A8580BDC82D3DC6C
E: The repository ‘https://brave-browser-apt-release.s3.brave.com stable InRelease’ is not signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
the net is that the install file does not get made available.
a few things occur to me:
i hope this is worth the trouble
more importantly, for a product that promotes itself based on privacy and security, I have to admit I find these particular errors and warnings attention getting.
I am sorry to continue to make you my victim, given your kindness in responding, and am actually replying to you, also in case someone from the company sees this and can appreciate how it looks from out here.
I remain willing to give this a bit more time, but not much more…as it is disconcerting.
nevertheless, I continue to appreciate your courtesy
you very welcome @OM1
and when you first install the app you need to accept the pgp key which used to verify integration and security of the instaltion files
it more advanced way than the sha256 and those things
let me ask someone from the team @fmarier as i forget how to fix this one
if this key issue is not new…as of course, I never got to the install part, really…one wonders why it has not been fixed, as when I look at the exec team on the brave site, there are many individuals in the company now and there has been 7 figures of financing. one would hope there are some front line troops to address fairly simple coding matters such as this one.
I am getting error message from the forum when i put your four commands in this note with the corresponding results underneath them to try to make this easy to read. it says something to the effect that new posters cannot put more than 4 links in a post.
I think you might be able to work-around this forum restriction by putting three backticks (```)on a line by themselves before and after your output. That way the URLs in the output will not be turned into links. It would look like this:
i am always in learning mode, as I am in a sensitive business, and always want to understand my tools before they do what they want and my not being able to know why.
so my question to you, pending my trying what you suggest, and provided that I used the script from your site, literally, is “why” this file is not there.
is it that some machines do not respond the same way with the same script (I used “terminal” in an otherwise perfect install of ubuntu) or is there something else that I failed to do, myself?
ps i ran the additional command from your email and got the output you said I needed.
later tonight or tomorrow, then, I will run the entire install script again, taking it from your site instructions, and hopefully that will do it. I will let you know if there are any other issues, but thanks.
That’s a good question and one that can’t be answered without seeing a copy of all of the messages that were in your terminal when you went through these steps the first time
ok…well, since that is unknowable at this point, it is what it is.
the program is installed and running, I have used “advance” settings to get there I want to be, and I will continue to use it…with a view toward making it my default browser.
