When I access to a website that contains the option to run a small script written by me on the site, Brave seems to block it.
I tried to disable the Brave ad-blocker and to allow javascript but still not worked.
- Go to a website that runs and shows a piece of code like this: https://js.do/
- Try to get an output, you will see the result for half a second appear and then disappear.
Output of the code snippet.
Version 1.21.44 Chromium: 88.0.4324.146 (Official build) beta (64 bit)
(PS. Tested this also on the current stable version of Brave (07/02/2021)).
