Right click menu not working on separated tabs
Every time I separate a tab to a new window the right click menu on that tab does not open. If I open new tabs in the new window the right click menu works but it does not work on the original separated tab that was used to create a new browser window.
Brave 0.18.36
Hi @Juan_Olivier,
Thanks for reporting! This one is known issue and logged in the link below. I added your comment as +1 and you can track the progress here:
Thank you,
:slight_smile:
