Right click does not work
Right click does not work on new tabs. Specifically, after placing new tabs on second screen (I use two monitors).
Hi @insidentes
Could you please provide details as per the post below so we can better assist?
Thanks,
Lauren
#3
I’m having the same issue. Brave version 0.17.13. Windows 10 Pro 64 Bit. Default shield settings.
This can be repeated 100% of the time by dragging a browser tab out of a browser window, into it’s own window. Right clicking links then doesn’t work in the new window.
#4
It seems related to this one from this thread (re: context menu not working after tear-off tab).
@insidentes @timshep_7 can you confirm if this is the same issue?
Open issue: https://github.com/brave/browser-laptop/issues/9741
#5
Yes that is the same issue.
#6
Thanks for confirming, @timshep_7. I added your comment to the GitHub issue. You can track the progress there.
Thank you,
:slight_smile:
closed #7
