Rewards Vanished, they were there, then they were gone
Briefly describe your issue: Claimed rewards, they were there. Then they were gone
What Operating System and Brave version are you using (Menu --> About Brave)? Windows 10, latest version
Is your browser wallet currently verified? (yes/no) Yes
What date did you verify your wallet? 4/7/2022
Have you been able to successfully receive payments in the past? First time
Are you using a VPN? (yes/no) No
Are you in a supported region (see here for list of supported regions)? Yes
Does your device pass the SafteyNet check (Android only)? NA
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? Yes
We are actively working to ensure that each user receives the correct amount of BAT for the April payout. If you have received less BAT than expected this month, please note that payments to verified wallets and claims for unverified wallets will continue to process through next week. Thank you for your patience as we work to complete your payments.
To ensure that future payouts go more smoothly, we will be investing additional time and resources into improving tooling and communication around the payout process. We thank you for your patience and continued support of Brave Rewards.
Please follow this thread for further updates regarding April payments - Ads Payout Status Update.
Thank you for your patience!
