Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
- How do I opt into Brave Ads?
- Why am I not seeing Brave Ads?
- Windows 10 Ads Troubleshooting
- Rewards FAQ
Briefly describe your issue:
Rewards stuck and not increasing or transferring to Uphold anymore
Mac OS Monterey ,
Version 1.40.107 Chromium: 103.0.5060.53 (Official Build) (arm64)
Yes
About a year ago
Yes
Are you using a VPN? (yes/no)
no
Yes
N/A
Yes
