Rewards not received after claim
Briefly describe your issue: I claimed the august rewards in the desktop browser yesterday. They show in the statement, but were never received by Gemini. the mobile android browsers rewards showed up as usual.
Windows 11, brave 1.43.89
Is your browser wallet currently verified? (yes/no) Yes
a long time ago…
yes
Are you using a VPN? (yes/no)
No
Yes
Yes
Are you still connected to Gemini?
If yes then, Brave is having some issues for gemini users. they are fixing it. You can see it in the post below →
