ryabj
1
Ads have stopped and the rewards page displays only a small white box
I do not know how to reproduce this issue for another user. Ads and rewards page stopped working properly approx. 14 hrs ago.
v0.68.131
have not touched any settings or options
e: have just received an ad and can access rewards through the "customize and control’ menu. got credited. drop down still has a white square.
Hi @ryabj
Welcome to community! Can you share a screenshot of the white square?
Hey @steeven,
I have the exact same issue. Here is the screen :
My Brave Version : Version 0.68.131 Chromium: 76.0.3809.100
Thanks !
Hi @horatiounaee, is that MacOS or Windows?
@steeven Windows 10, Version 1903
edit : Just updated to Brave Version 0.68.132 Chromium: 76.0.3809.132, issue is still here
ryabj
6
@steeven exactly the same as @horatiounaee
it is just the square though. rewards and reward page are still working.
imkzru
7
To any constellation I’m having the same issue. Small white box when the Brave rewards triangle is clicked…
Brave version - Version 0.68.132 Chromium: 76.0.3809.132 (Official Build) (64-bit)
Windows version - Windows 10 Pro / version 1903 fully updated.
I have reset browser to defaults with no joy.
Note:
if you right click in the small white box you get options please see image
I can confirm this as well. Same small white box.
On my second browser at home, it works fine, but the Rewards Pop Ups are glitched. A faded white box with barely readable text and no close button.
Hi @ryabj @horatiounaee @imkzru,
Thanks for your patience here. This is a known issue and can be tracked here - https://github.com/brave/brave-browser/issues/5336.
It is currently in Beta and should be in Release in 0.69.
system
Closed
10
