There was a post previously by @K0b0L which was closed with no solution. As I found a solution, I wanted to drop a quick post to help others that encounter the same problem.
Previous post is here: No Sound is played on Tradingview.com
Sound alerts are vital for any traders using tradingview. For some reason the sound stops working unexpectedly after upgrade or without any known cause and never comes back.
Wait for an alert to come or create a new alert easily triggered.
Alert triggers only Pop-up Notifications without any sound
Alerts triggers with Sound + Pop-Up Notifications
Once the issue starts, it allways repeats
page in the main menu):
Currently settings:
- Win 10 1903
- Brave 0.67.124
How to fix:
- On tradingview website, click on the lock next to address bar
- Click on site settings
- Under usage click Clear data & Under Permissions click Reset Permissions (regardless if “Allow” is set for all settings)
- Wait for next alert which will have sound and when the pop-up to change settings appers, click allow sound.
Hope this helps.
