Remove Pin from right-click menu (2nd attempt for help)
How can I remove some options from the right-click menu when right-clicking on the browser tabs? I commonly “Duplicate” tabs, and about 1 out of 20 times, I’ll inadvertently tap on “Pin”.
I never Pin tabs, because the Pinned tab is too small to differentiate it from another tab if they all show the Lion icon.
  1. Right-click on any browser tab
  2. note that “Pin” is an option
Pin is not an option, but can be re-enabled in Brave settings
1.60.110
