You will not be able to connect to Uphold because your country is no longer supported.
But you should be able to received the future rewards in your browser. If you do not, then please open a support ticket.
Tell me, it’s permanent?
No. Brave is trying to find a solution. But it may take several months until most countries are supported.
There is a post with some updates on this subject.
Oh, no!!! It’s not fair!!!
