Problems with Uphold
I´ve been using Brave rewards for a year, more or less, but my rewards continue in zero, I turn off auto contribute to creators, I was using iOs on Iphone, but now I´m using windows on a Laptop and don’t find how to fix this problem.
Additionally I was trying to create an account in Uphold and it’s not working, the page doesn’t go ahead after introducing my email, country, password
Please help
What do you mean? Please elaborate.
Does the same happen at
https://wallet.uphold.com/signup
I am asking since there’s a bug which is not allowing to create an Uphold account from the rewards section so just wanna confirm
Also if you’re from a region listed at
Then only you’ll be able to connect brave rewards to Uphold. Otherwise you’ll just have an account but won’t be able to connect to Brave rewards.
