I can’t login to twitch and it won’t let me make payments within twitch
12:00 PM 09/23/22
1.Throughout the day I have had the problem with twitch that it does not let me log in to brave and it is strange since in brave it did let me open it and in terms of payments it simply does not show me the option to buy or hides it, I have the ad blocker option turned off for the same reason so that it lets me watch twitch
Versión 1.43.93 Chromium: 105.0.5195.127 (Build oficial) (64 bits)
](https://brave.com/latest/) apologies for the translator’s english
I came here to say the same thing. Both release and beta brave are affected on my desktop and laptop. I have not tried nightly yet. Chrome on the same PC works (same chromium version)
EDIT
Since I am at my reply limit as a new user here, I’ll add Twitch Support’s newest reply to me here, so make of it what you will:
Thank you so much for reaching out about your concerns. We genuinely apologize for any frustration involved.
Based on the information provided, it looks like this is currently a known issue that we’re actively working to resolve as soon as possible. We are unable to provide an ETA for resolution, however we appreciate your patience in awaiting this fix.
To add more information, where twitch would normally show the 2FA prompt, I get an error that “something went wrong” instead, and to try again. Chrome shows the 2FA prompt after logging in at this point in the process. Shields are off, tried turning off all extensions, used a different pc, installed brave beta- nothing helped. I started noticing weird issues not working yesterday with the platform, so I’m not sure what changed, if it was in brave, or on twitch’s end.
Hi, I also had the same problem, I had to disable all the “shield” protections temporarily to connect, then after I could put everything back to normal.
I have tried Disabling all settings on the shields page, resetting site-specific permissions, enabling EVERYTHING relating to cookies, popups, redirects, etc. and still cannot get to the 2FA.
I saw the gif in the other thread, is that the current version? I cannot reproduce that behavior.
EDIT*
Since it will not let me add a new reply to this thread as I am new here, here are the screenshots of my attempt to follow the latest instructions of clearing my cookies, ensuring aggressive fingerprinting is off, and re-logging in. Still same result.
