Problems using LinkedIn with Brave
Dear Brave developers.
I’ve been using your browser for a while now, but I’ve noticed that there are some issues, especially when using LinkedIn. It seems the browser can’t handle URLs with a combination of Latin and Cyrillic.
The other similar problem is that for some time I can’t open the posts of someone I follow. I can email the broken hyperlinks.
Thanks for the otherwise good work!
Regards,
Lyubomir Lyubomirov
@L.Lyubomirov,
Can you share those links that aren’t working in the browser? Additionally, can you describe a bit more about what happens when you try to open the posts of some of the people you follow? Is it always viewing posts from the same people? Does viewing posts work generally?
Viewing posts works in principle. But opening certain posts doesn’t work - I end up in the feed. I can see some of the posts if I go to the profile of the person who published them. But there are some that I can’t open at all, for example:
@L.Lyubomirovl,
On my end, this user’s profile page is visible but I cannot view any o this user’s posts — the page loads but comes up blank. Is this also what you see on your end when you try to view his profile?
Yep, that’s exactly what’s happening to me too - I can’t see any of this guy’s posts, but I used to be able to. The weird thing is that when I’m not on LinkedIn and try to browse some of the links I can see the posts. With another browser, for example Edge, I have no such problems.
Looks like it’s specifically the Block ads and trackers protection of Shields that causes the issue. If turn Shields off or set that protection to Allow[...] then I am able to view the page properly.
Going to loop in @fanboynz here to take a look. Appreciate your patience.
How about a different user? does it occur on other users?
I got a problem; it’s a weird corner case though. I mostly log in to follow certain people; one of them, Valeriy Manokhin, has a feed which doesn’t quite work unless I put shields down. I suspect he turned on some marketing doodads with extra tracking. Anyway maybe others can have a look and see if it’s same problem for them:
https://www.linkedin.com/in/valeriy-manokhin-phd-mba-cqf-704731236/recent-activity/all/
With shields up, I only see his reposts, rather than his active posts. Shields down I see the whole feed.
