Me es imposible agregar un site en las pestañas favoritas. Puedo borrarlas, pero agregar no responde, reinicie Brave, sin exito. Alguien ayuda?
Translated via deepl.com
TITLE:
Problems with the Customization Panel
CONTENT / DESCRIPTION:
It is impossible for me to add a site in the favorite tabs. I can delete them, but add does not respond, I restarted Brave, without success. Anybody help?
Please edit your Original Post, in order to include:
(Por favor, edite su Post Original, con el fin de incluir:)
- Brave Browser version numbers
- (Números de versión del navegador Brave)
- Operating System version numbers
- (Números de versión del sistema operativo)
v1.76.81
Windows 10
May be helpful info:
Add to the favorites" option has disappeared - #4 by Mattches
the option will not appear if the site is already added to favorites — can you confirm whether or not this is the case for you?
Simply visit a site that is not already part of your favorites and see if the option appears in the menu.
thanks,the problem solved itself.
