Problem with vertical tabs on the right
Hello.
I’m using the minimized vertical tab bar on the right. It’s all great aside from one annoyance. When I hover mouse cursor over the tab bar to reveal the tabs, the cursor almost always lands on the X button so it’s very easy to accidentally close a tab instead of selecting it. Not sure what the fix might be. Maybe for the right side tab bar show the close button on the left and fav icon on the right?
Windows 11
Just my two cents.
I echo this completely. I love the vertical tabs, love the minimized view with auto-expand, love having it on the right side. Hate that every time I go to switch tabs, I accidentally close the tab I want bc it auto-expands with the close “X” right where my cursor was. Having it on the inside(closer to the center of the window) edge, or just inside the site icon even would be make the setup just about perfect.
Windows 10
I do see what you’re saying. While I can’t guarantee any sort of timeline that this would be looked at, I have opened this issue for the devs to review and consider:
