Problem with TrustedShops logo block
Brave browser is blocking TrustedShops logo for verified sites.
Screenshot of the ad as it appears in Brave
Yes, default shield ON
Yes, logo is visible when shield is OFF
No specific configuration.
Yes
1.31.88
Hi,
It’s blocked in Easyprivacy due to privacy. The “widgets.trustedshops.com” javascript has tracking in it, not just an image here.
If you (really) need trustshops, add this into brave://adblock @@||widgets.trustedshops.com^
Thank you for your reply.
I’m responsible for the shop itself, I’m rather thinking how to solve the issue so other people/customers can see the logo/widget…
Hi,
Its a privacy issue between the enduser, Easyprivacy and trustedshops. trustedshops uses anayltics to track browser details, user agent etc. So until that changes it’ll stay in Easyprivacy (and remain blocked), user privacy always comes first for Easyprivacy and Brave.
