Briefly describe your issue:
Problem with Transfer BAT to Gemini and problem with gather new BAT
Version 1.29.81 Chromium: 93.0.4577.82 (Official Build) (x86_64) macOS Big Sur
yes, gemini
What date did you verify your wallet? Today
Have you been able to successfully receive payments in the past? yes, last time in July.
Are you using a VPN? (yes/no)
No with Brave. VPN installed since few days for work related job.
yes
Not applicable.
More information:
Since July I did not have more BAT added to my account, but I received ads. Count for ads received for this month show “0”, but if I open “30-day ads history”, then I see 12 ads from this month.
Till now I did not control this, as I have seen some BAT in my wallet and I have too less BAT to start process at Uphold. Today I have seen at start page information about Gemini and decided to register and earn 5 additional BAT after linking Gemini account with Brave. (There were no limit for BAT it’s looks like offer for me) after I connected Brave with Gemini I lost my BATs. Now… I am not receiving new BAT from ads and lost BAT already earned. I also do not have promotional BAT from Gemini, but I already found, that I need to wait about 30 days for it.
- How I can fix this and transfer my BAT to Gemini?
- How I can fix this and start earning BAT again from Ads?
Logs: (Maybe help as well, I do not know, what I can copy for second issue)
[30 Oct 2021, 2:57:03.2 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 2:57:03.2 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 2:59:21.1 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 2:59:21.1 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 3:14:33.8 pm:ERROR:refill_unblinded_tokens.cc(189)] Failed to get signed tokens
[30 Oct 2021, 3:20:39.0 pm:ERROR:refill_unblinded_tokens.cc(189)] Failed to get signed tokens
[30 Oct 2021, 3:41:47.4 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 3:41:47.4 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 3:42:56.2 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 3:42:56.2 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 3:43:06.7 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 3:43:06.7 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 3:43:53.7 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 3:43:53.7 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 3:43:57.6 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 3:43:57.6 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 3:59:07.5 pm:ERROR:publisher.cc(774)] Publisher info not found
[30 Oct 2021, 4:09:08.5 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 4:09:08.5 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 4:09:47.8 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 4:09:47.8 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 4:12:41.7 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 4:12:41.7 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 4:14:43.4 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 4:14:43.4 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 4:27:34.4 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 4:27:34.4 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 4:57:39.1 pm:ERROR:refill_unblinded_tokens.cc(189)] Failed to get signed tokens
[30 Oct 2021, 5:49:51.7 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 5:49:51.7 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
[30 Oct 2021, 5:55:53.4 pm:ERROR:gemini.cc(133)] Couldn’t get balance
[30 Oct 2021, 5:55:53.4 pm:ERROR:wallet_balance.cc(225)] Can’t get gemini balance
[30 Oct 2021, 6:32:15.0 pm:ERROR:refill_unblinded_tokens.cc(189)] Failed to get signed tokens
[30 Oct 2021, 6:51:54.0 pm:ERROR:credentials_promotion.cc(503)] Token list empty
[30 Oct 2021, 6:51:54.0 pm:ERROR:gemini_wallet.cc(51)] Claiming tokens failed
Thank you!
