Hello there!
I’m using Brave since 2023 and love using it. However, since last few months I’m observing some unusual behavior under the “Sync” option. I’ve connected 4 devices in a chain, namely Desktop-0MLDVV2 (that’s my laptop), SM-E146B (my smartphone), Redmi Note 7 Pro (my mother’s smartphone) and 23027RAD4I (another phone used by mom). However, everytime I open “Sync” my laptop’s name is shown ample number of times (please refer to screenshot attached). I tried to remove them manually but they reappear again. This is happening with my laptop only and I’ve seen the other 3 smartphones connected in the Sync chain works pretty well and do not show this unusual behavior as happening with my laptop.
Brave version on my laptop:
Version 1.69.162 Chromium: 128.0.6613.120 (Official Build) (64-bit)
Brave version on my android: Brave 1.69.164, Chromium 128.0.6613.127
Operating System- Android 14; Build/UP1A.231005.007
I hope the support team looks after this issue and it is solved at the earliest. Hope to hear from you soon and thanks in advance and regards.
Krishna Dwaipayan Mitra
(A regular Brave user)
