problem with receiving BAT and BAR survey
it’s been more than 2 months since a single bat hasn’t been verified and I can’t remove the ones I have, I already have an account and it’s already verified, would you like a solution
Please provide the following basic troubleshooting information, which is needed to help diagnose your issue:
Briefly describe your issue:
Are you using a VPN? (yes/no)
Have you manually turned OFF Auto-contribute on all of your devices linked to Uphold??
