Greetings. I hope you can help me out. I have a pc assembled by me. The video card is an amd 6700 xt. Sometimes while I’m on Brave doing something, suddenly the monitor turns off. I try to disconnect and reconnect the display port cable and the monitor resumes. Other times the same thing and amd’s Andrenalin settings are reset. Once, the speakers also rattled with the monitor off and I had to reboot.
I would like to understand if it is a problem only with brave (since it seems to me that it only happens with him), or if I have to worry about something else. How can I solve? Thank you
** How can this problem be reproduced? **
** Expected result: **
** Version 1.43.89 Chromium: 105.0.5195.102 (Official Build) (64-bit) **
Additional information:
