Problem with Bookmark Extension Switchmarks
I used the Bookmark Bar Manager “Switchmark” with Brave. Until the last version it was working perfectly, but now Brave crashed when I click on the icon to change the Bookmark.
Download the Switchmarks Extension here:
Click on the Blue Icon in the Extensions bar.
Windows 10, Version 1.2.41 Chromium: 79.0.3945.88 (Official Build) (64-bit)
With my research I found out, that this could be an issue of this change in the latest version:
Would be nice if you could recommend a workaround or get the extension work again in the next version.
Edit: I just found out that there is also a problem now with this extension:
Thank You.
@djottic,
Thanks for reaching out. I went ahead and tested this myself and it appears that you are correct – attempting to use Switchmark freezes and (ultimately) crashes the browser. I’ve opened the following issue for the developers to review:
